[GRASS-user] Can't dissolve based on column?
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Wed Jan 16 17:30:06 EST 2008
Are there plans to change the "TEXT" problem with respect to v.dissolve
(v.extract)?
I need to know, if it possible, due to some documentation I am
preparing.
Thank you!
On Wed, 2008-01-16 at 22:08 +0100, Martin Landa wrote:
> Hi,
> 2008/1/16, Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>:
> > My column "CODE_00" was identified as "TEXT", not "varchar". So maybe
> > this was the problem (?)
> > I merged the tiles outside of GRASS with ogr2ogr -update -append... etc.
> > I did not try to merge with v.patch the tiles.
> > Is there a difference?
> yes, right. It fails when 'text' data-type is used. It should be
> fixed. I will try to take a look as soon as possible.
> Martin
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080116/95af1b5e/attachment.bin
