[GRASS-user] i.landsat.rgb problem
    Leonardo Lami
    lami at faunalia.it
    Thu Jan 17 06:42:40 EST 2008
Hi all,
i tried i.landsat.rgb on GRASS 6.3 but I have this error message and the
color tables of the three raster are setted with all values white.
I obtained this three brov raster from i.fusion.brovey applied on
Landsat images.
i.landsat.rgb -p red=brov.red at PERMANENT green=brov.green at PERMANENT
blue=brov.blue at PERMANENT strength=90
Processing [brov.red at PERMANENT] ..
/usr/lib/grass/scripts/i.landsat.rgb: line 138: [: 36.9801: integer
expression expected
/usr/lib/grass/scripts/i.landsat.rgb: line 141: [: 15.7707: integer
expression expected
Processing [brov.green at PERMANENT] ..
/usr/lib/grass/scripts/i.landsat.rgb: line 138: [: 39.6825: integer
expression expected
/usr/lib/grass/scripts/i.landsat.rgb: line 141: [: 15.1483: integer
expression expected
Processing [brov.blue at PERMANENT] ..
/usr/lib/grass/scripts/i.landsat.rgb: line 138: [: 24.107: integer
expression expected
/usr/lib/grass/scripts/i.landsat.rgb: line 141: [: 13.1111: integer
expression expected
Color table for <brov.red at PERMANENT> set to rules
Color table for <brov.green at PERMANENT> set to rules
Color table for <brov.blue at PERMANENT> set to rules
Thank you
Leonardo
