[GRASS-user] Can't dissolve based on column?
nikos.alexandris at felis.uni-freiburg.de
Thu Jan 17 07:05:02 EST 2008
Sorry for typo's!
On Thu, 17 Jan 2008 13:02:54 +0100
nikos.alexandris at felis.uni-freiburg.de wrote:
I just wonder how was the tile-patching and dissolving
(of CORINE shapefile(s)) done, as described in
v.dissolve's help text?
Were the file's "CODE_00" column different than "TEXT" ?
> But anyway is good to make things as much as possible
> more
> transparent. I learned a lot from this small story.
> Thanks!
> On Wed, 16 Jan 2008 22:26:45 -0500
> "Patton, Eric" <epatton at nrcan.gc.ca> wrote:
> > Eric Patton wrote:
> > > > Just a clarification...so it's the case that the
> > column parameter
> > > > in v.dissolve must always be of type integer, and
> > *only* integer?
> > Hamish:
> > >The v.dissolve script with dissolve based on a column
> > currently
> > >requires that column to be of type integer. We should
> > probably add a
> > >check in the script for that (v.info -c).
> > Ok, that's what I thought; thanks. I wanted to make
> sure
> > before I added a hint in the docs.
> > Actually, I think Nikos mentioned something about
> writing
> > up a hint about it, so I'll hold off.
> > >It would be possible to add any type of column to
> > v.dissolve with unix
> > >tools 'db.select | sort | uniq | nl' then create a new
> > table with the
> > >unique attributes + sequential integer column, then
> > v.reclass as
> > >before.
> > >or add a new column to (a copy of) the existing table
> > (v.db.addcol) and
> > >populate it with a 'db.select | sort | uniq' loop and
> > v.db.update, or
> > >SQL + db.execute << "set DISOLVEKEY = $i where
> ATTRIBUTE
> > = '$VAL'"
> > >(sorry my SQL is not good but you may be the idea of
> > what I mean)
> > Cool. It's always amazing how powerful these little
> > command line tools can be.
> > ~ Eric.
> Nikos Alexandris - Ph.D. Candidate
> Department of Remote Sensing
> and
> Landscape Information Systems
> (FeLIS)
> Faculty of Forestry and Natural Environment
> Albert-Ludwigs-University Freiburg
> Tel. +49 (0) 761 203 3697
> Fax. +49 (0) 761 203 3701
> Skype: Nikos.Alexandris
> Address: Tennenbacher str. 4
> D-79106 Freiburg i. Br.
> Germany
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
and
(FeLIS)
Germany
