[GRASS-user] When starting grass in text mode,
why... ? (Question of minor importance)
Patton, Eric
epatton at nrcan.gc.ca
Thu Jan 17 09:08:36 EST 2008
>could you try editing your $GISBASE/etc/Init.sh file and change the top
>line to "#!/bin/sh -x". That will show gratuitous script progress info
>and hopefully tell us which command is causing that message.
>Hamish
No need; I found the thread:
http://article.gmane.org/gmane.comp.gis.grass.user/14406/match=login+message+sudo
I can confirm that if you create a file called .sudo_as_admin_successful in any $LOCATION/$MAPSET,
the messages stop when Grass enters that location only. I have no idea what consequences might occur
if this file is automatically generated by Init.sh for every new mapset (maybe none?).
~ Eric.
