[GRASS-user] How to list all unique pixel values (of a raster)
covered by polygons (areas) for each polygon separately(?)
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Thu Jan 17 21:23:54 EST 2008
Giovanni,
thank you for your proposal.
The link to the FAQ (the one that Jose provided) looks like a solution.
But your idea is clever as well and I had a similar way in my mind.
If I got it correct you suggest:
1. VectorTargetAreas ~~~v.to.rast (based on unique attribute like cat
or FID~~~> RasterTargetAreas (all pixels of a "TargetArea" have now the
same value
2.MASK out everything besides the "TargetAreas" ---looping to create as
many MASKS as the the number of the "TargetAreas"
3. For each MASK run r.stats
4 (I would also like to have) add the output list(s) as a new table
(column pixval) into the initial VectorTargetAreas (with db.connect,
db.addcol, etc). Let's say for a polygons which covers 20 pixels it
would be like:
FID - cat - pixval
1 - 1 - 200
2 - 1 - 198
3 - 1 - 234
20 - 1 - 765
Is it possible to put all this together?
r.stats and output into a new column (pixval)
On Thu, 2008-01-17 at 18:25 +0100, G. Allegri wrote:
> Just a rapid idea.
> You could make just one rasterized map of your polygons and then
> insert in a loop this, giving each pixel a unique category value:
> r.mapcalc "MASK = if(raster=$i,1,null())"
> with $1 the cat value (deriving from you original polygon)
> and then run r.stats, which will work only for the un-masked pixels.
> I don't have time to try this method, hope it helps.
> GIovanni
> 2008/1/17, nikos.alexandris at felis.uni-freiburg.de
> <nikos.alexandris at felis.uni-freiburg.de>:
> > Salut Jose!
> > This is what I am doing... and I only have 7 polygons - so
> > it is ok.
> > But if I have 50 polygons... I am not so sure how to script
> > it to get (finally) a table with all pixels for each unique
> > polygon for 2 different images of the same location (for
> > raster MODIS year 2006 and then another of the same area
> > MODIS 2007!).
> > I want to run a regression with the pixel values... (pairs
> > of 2006 and 2007 values).
> > Thank you,
> > Nikos.
> > On Thu, 17 Jan 2008 16:42:31 +0000
> > "Jose Gomez-Dans" <jgomezdans at gmail.com> wrote:
> > > On Jan 17, 2008 4:30 PM,
> > > <nikos.alexandris at felis.uni-freiburg.de> wrote:
> > > > How can I get listed all unique pixel values enclosed
> > > in
> > > > each of the polygons I digitised (and for which the
> > > univ.
> > > > stats are calculated)?
> > > Can't you just rasterise your polygons, and use that as a
> > > mask with
> > > r.mapcalc? You can loop around in your shell. I tend to
> > > do that with python,
> > > but it's similar in GRASS. You can also try starspan.
> > > Or.... <
> > > http://grass.gdf-hannover.de/wiki/Aggregate_Values>
> > > Cheers,
> > > Jose
> > > Centre for Terrestrial Carbon Dynamics
> > > Department of Geography, University College London
> > > Gower Street, London WC1E 6BT, UK
> > Nikos Alexandris - Ph.D. Candidate
> > Department of Remote Sensing
> > and
> > Landscape Information Systems
> > (FeLIS)
> > Faculty of Forestry and Natural Environment
> > Albert-Ludwigs-University Freiburg
> > Tel. +49 (0) 761 203 3697
> > Fax. +49 (0) 761 203 3701
> > Skype: Nikos.Alexandris
> > Address: Tennenbacher str. 4
> > D-79106 Freiburg i. Br.
> > Germany
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080118/2cadbd4e/attachment-0001.bin
