[GRASS-user] starting nviz causes blackscreen and logout
Markus Neteler neteler at osgeo.org
Tue Jan 22 03:30:16 EST 2008
did you update Xorg but forgot to re-install the OpenGL
driver for your video card? Since nviz uses OpenGL, this could
be a problem.
Markus
On Jan 21, 2008 6:07 PM, Philipp Steigenberger <userlist at online.de> wrote:
>  Hi
>  since today I have a problem with nviz. last week it has been working very
> well but today *surprise* data loss :o(
>  First time I met the problem I started nviz with a rasterfile and
>  GRASS:~/gw$ g.r -p
>  projection: 99 (Transverse Mercator)
>  zone:       0
>  datum:      potsdam
>  ellipsoid:  bessel
>  north:      5348531.5719558
>  south:      5317450.80738016
>  west:       4397442.97214944
>  east:       4422732.52916468
>  nsres:      30.00073801
>  ewres:      29.99947451
>  rows:       1036
>  cols:       843
>  cells:      873348
>  nviz map vect=map1,m ap2,map3
>  I got the two little windows for some seconds and than the screen went
> black and I had to login again. Fortunately I didn't lost that much data.
> Just some lines in kate.
>  I can reproduce this problem
>  It also happens with a resolution of 100m and without vector files or just
> if I start nviz quickly without any map.
>  (last week I used nviz with a bigger map in a very high resolution without
> problems =-O )
>  I made a reboot and tried it without any other program running.
>  I use GRASS 6.3.cvs (2007)
>  on
>  System Information
>  Platform                Unix
>  Operating System     &nbsp ;  Linux
>  OS Version              2.6.22.13-workstation-4gb-smp
>  Processor Type (arch)   i686
>  Full OS ID              Linux-2.6.22.13-workstation-4gb-smp-i686
>  Tcl Version/Patchlevel  8.4.12
>  any suggestion?
>  Thank you
>  om shantih
>  Philipp
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
