[GRASS-user] Collapsing many layers into 1
Martin Landa
landa.martin at gmail.com
Tue Jan 22 04:58:18 EST 2008
2008/1/22, Neil Godfrey <neil at thegodfreys.net>:
> The census 2000 administrative boundaries are shapefiles, where every
> county is a separate file. So v.in.ogr creates a layer for every
> county. So for example, I get 83 layers for the 83 counties in
> Michigan, which correspond to 83 tables, each with just one category.
> What I want is one layer with 83 categories. I've had no luck with
> v.overlay, v.extract, v.patch, etc. because all those tools preserve the
> layers in the output map.
> Is there any way to do this?
If the attribute tables have the same structure (number of columns,
data types and key column), you can patch maps using
v.patch -e in=`g.mlist vect pat='con*' out=con_patch
v.clean in=con_patch out=con_clean tool=snap,break,rmdupl thresh=[value]
Martin
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
