[GRASS-user] Variables in r.mapcalc other than raster?
    Glynn Clements
    glynn at gclements.plus.com
    Tue Jan 22 23:07:07 EST 2008
Roland Pape wrote:
> I have to perform some complex calculations on several hundreds of maps
> using a shell script. A set of variables would ease the task, therefore
> my question: Is there any possibility to use a set of predefined
> variables (no maps!) in r.mapcalc? - It seems to me as if it is always
> looking for maps and consequently states "i is not a map".
Where does r.mapcalc get the expression from? If it's passed as a
command-line argument, the shell will perform variable substitution
within a double-quoted string. The shell will also perform
substitution within here documents.
If the expression is being read from a file, you'll need to arrange
for the substitutions to be performed using e.g. sed.
