I'm trying to dissolve (on an integer column) a vector map. It works well but no table is created. The db.connect -p reports : driver:dbf database : ....... /dbf/ schema : (null) group : (null) and the dbf/ subdirectory already exists in the mapset What's the problem ? Thank you,
