[GRASS-user] GRASS & QGIS
Jachym Cepicky
jachym.cepicky at gmail.com
Fri Jan 25 01:48:29 EST 2008
once, I saw it by some guys from Germany. They read tons of data from
Oracle using Qgis.
Only thing you have to do is to compile ogr library with support for
oracle.
#1 download debian development tools
apt-get install dpkg-dev
#2 download the source code of GDAL library
apt-get source gdal
#3 go to gdal directory and adjust rules file in debian directory
cd gdal-1.4.2/debian
vim rules
--with-ecw=yes \
--with-pg \
--with-ogdi \
--with-mysql \
--with-perl \
--with-ruby \
# add the oracle stuff here
--with-oci=/path/to/oracle/home
--with-oci-include=/path/to/Oracle/OCI/API/headers
--with-oci-lib=/same/for/libs
#4 then you can run dpkg-build package and install missing packages,
until dpkg-buildpackage does not successfully build gdal package in ../
directory
#5 install generated packages with dpkg -i ../*gdal*deb
and it should work. you should be able to view oracle data from qgis, as
well as import them to grass
jachym
Jacques Schalkwyk píše v St 23. 01. 2008 v 22:27 +0200:
> Hi all.
> I trust there is life out there. Sometimes I wonder as this mail is
> comming from deep darkest Africa.
> I am a newbie to linux and grass and i would like to have Qgis access
> data directly from an oracle spatial data base. I am running ubuntu
> 7.10 as an operating system. Any assistance would be greatly
> appreciated. I can be contacted directly at
> jacques.schalkwyk at finfreeadmin.com
> Best regards
> From the oldest newbie in this neck of the woods
> Jacques Schalkwyk
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Jachym Cepicky
e-mail: jachym.cepicky at gmail.com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Name: not available
Desc: Toto je =?UTF-8?Q?digit=C3=A1ln=C4=9B?=
=?ISO-8859-1?Q?_podepsan=E1?= =?UTF-8?Q?_=C4=8D=C3=A1st?=
=?ISO-8859-1?Q?_zpr=E1vy?=
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080125/f135feab/attachment.bin
