[GRASS-user] Re: how to get categoriy values after v.reclass?
Patrick Giraudoux
patrick.giraudoux at univ-fcomte.fr
Sun Jan 27 11:51:13 EST 2008
Patrick Giraudoux a écrit :
> I had a point vector map of three points (name = 'samples') where the
> category values were 1, 100, 200
> I reclassified it as following:
> v.reclass input=samples output=samples2 rules=reclasscode
> where reclasscode is this file:
> > cat reclasscode
> cat 1
> where cat=1
> cat 2
> where cat=100
> cat 3
> where cat=200
> Then, I cannot find a way out to read the values of cat in the new
> file 'sample2'. Obviously v.info could just give the names of the
> columns in 'samples':
> > v.info -c map=samples
> Displaying column types/names for database connection of layer 1:
> INTEGER|cat
> INTEGER|ID
> DOUBLE PRECISION|x
> DOUBLE PRECISION|y
> but with the new file
> > v.info -c map=samples2
> ERROR: Database connection for map <samples2> is not defined in DB file
> and anyway, this is not exactly what I would like to get. I would get
> the value of the categories for each point... and cannot make it
> whatever the vector file...
> Any hint welcome !
Sorry to answer to myself, but it looks like
v.category input=samples2 option=print
makes it !
Patrick
