[GRASS-user] Snap across layers
Luca Casagrande
luca.casagrande at gmail.com
Mon Jan 28 10:37:07 EST 2008
Markus Neteler ha scritto:
> hi Luca,
> - v.edit does it:
> bgmap Name of background vector map(s) snap to
> - the new digitizer in wxgrass does it (not yet enabled by default)
> Cheers
> Markus
> On Jan 28, 2008 3:29 PM, Luca Casagrande <luca.casagrande at gmail.com> wrote:
>> Hello everybody,
>> anyone knows if is possible to do snap across different layers in Grass 6.3?
>> Thanks
>> Luca
Hi Markus and thanks for your answer.
Before moving to my data, I am doing some tests with 2 vector layers:
http://img337.imageshack.us/my.php?image=schermatamapdisplay1vp5.png
Basically the small one, should snap to the bigger one.
The command line I use is this:
v.edit map=origine bgmap=destinazione cat=1-999 tool=snap thresh=-1
But nothing change.
In the log I have got a lot of line like this, both if i set thresh -1
or 500
D1/1: Vect_set_thresh(): thresh = 0.000000
Thanks for your help
Luca
