[GRASS-user] Re: highest and lowest point in catchment
Richard Chirgwin rchirgwin at ozemail.com.au
Tue Jan 29 16:54:37 EST 2008
grass-user-request at lists.osgeo.org wrote:
> Send grass-user mailing list submissions to
> 	grass-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> 	http://lists.osgeo.org/mailman/listinfo/grass-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	grass-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of grass-user digest..."
> Today's Topics:
>    1. highest and lowest point in catchment (Dr. Manuel Seeger)
>    2. SHELL Variable problem: Workaround (Peter L?we)
>    3. Re: SHELL variable not set (Martin Wegmann)
>    4. Re: SHELL variable not set (Glynn Clements)
>    5. Re: SHELL variable not set (Hamish)
>    6. Re: SHELL variable not set (Markus Neteler)
>    7. Re: Building wxgrass vdigit (Martin Landa)
>    8. segment_format error with r.watershed (Wes Kent)
>    9. union features of vector (Alfredo Alessandrini)
>   10. Re: Snap across layers (Martin Landa)
> Message: 1
> Date: Tue, 29 Jan 2008 10:01:20 +0100
> From: "Dr. Manuel Seeger" <seeger at uni-trier.de>
> Subject: [GRASS-user] highest and lowest point in catchment
> To: GRASSLIST <grass-user at lists.osgeo.org>
> Message-ID: <479EEB60.6050606 at uni-trier.de>
> Content-Type: text/plain; charset=ISO-8859-15; format=flowed
> Hello all,
> I hope the questions does not seem too simple, but I have now no real
> good idea how to solve this simple problem:
> I need to find the highest and the lowest point within catchments WITH
> their coordinates (and to get the information about altitude and
> coordinates, of course)
> thanks for hints!
> manuel
Manuel - hope I'm not being silly here, but I'd consider just using an
SQL select directly to the data store.
Select max( <altitude column> ), <latitude column>, <longitude column>,
<any other column you want> from <table> where <boundary conditions of
catchment>
Select min( <altitude column> ), <latitude column>, <longitude column>
<any other column you want> from <table> <boundary conditions of catchment>
If you have to, you could extract only the catchment to a separate
vector, so that you don't need to fool around with complex boundary
conditions.
But I'm sure that a genuine Grass expert will have a simpler solution
than this ...
Cheers,
Richard
