[GRASS-user] Problems with v.to.db and v.db.addcol
Niels Thevs
nt001582 at uni-greifswald.de
Wed Jan 30 03:01:47 EST 2008
I tried the v.to.db (Windows-Grass) again. Today no error message came
out. But, with the default settings these messages came out:
v.to.db map=training_area_2_x_unsupervised_class_50 at PERMANENT
type=point,line,boundary,centroid layer=1 qlayer=1 option=area
units=hectares column=b_label
Updating database...
5104 categories read from map
5104 records selected from table
5104 categories read from map exist in selection from table
0 categories read from map don't exist in selection from table
5104 records updated/inserted
0 update/insert errors
Then, I changed type to area:
v.to.db map=training_area_2_x_unsupervised_class_50 at PERMANENT type=area
layer=1 qlayer=1 option=area units=hectares column=b_label
ERROR: value <area> out of range for parameter <type>
Legal range: point,line,boundary,centroid
Best regards
Niels
Markus Neteler schrieb:
> Could you please post the precise error message?
> Thanks
> Markus
> On Jan 29, 2008 8:54 PM, Niels Thevs <nt001582 at uni-greifswald.de> wrote:
>>Under my Windows GRASS GIS the commands v.to.db and v.db.addcol did not
>>work properly, when I wanted to calculate the areas of polygons. There
>>were error meaaages that it could not poen or execute the dbase files.
>>Does anybody how to overcome this problem ?
>>Best regards
>>Niels
>>Dr. Niels Thevs
>>Chair of Geobotany and Landscape Ecology
>>Institute of Botany and Landscape Ecology
>>Greifswald University
>>Grimmer Strasse 88
>>17487 Greifswald
>>Germany
>>Tel.: +49-3834-86-4137
>>Fax: +49-3834-86-4114
Dr. Niels Thevs
Grimmer Strasse 88
17487 Greifswald
Germany
