[GRASS-user] Building wxgrass vdigit
Craig Leat craig at pid.co.za
Wed Jan 30 09:21:42 EST 2008
Hi Glynn
Please see my comments below.
Glynn Clements wrote:
> Craig Leat wrote:
>> I then downloaded, configured and built trunk and the build
>> completed without reporting any errors. I noticed that vdigit was not
>> built along with the other modules, although a
>> /grass-trunk/gui/wxpython/vdigit/Makefile was generated. This concerns
>> me. Can anyone explain what's happening here?
I have already tried building the whole of GRASS, as described above. No
errors were reported, but vdigit wasn't built.
> You need to do at least "make -C lib headers" before trying to build
> anything else. Also, I suspect that it will expect to find the GRASS
> libraries in the build tree (in dist.<arch>/lib), so you will probably
> need at least "make -C lib".
> Personally, I would recommend just building the whole of GRASS, by
> running "make" from the top-level directory. Building individual
> components requires some knowledge of which parts depend upon which
> other parts, and acquiring this knowledge is likely to take somewhat
> longer than just building everything.
I'll try building the whole of GRASS again, just in case I missed
something and will report back. Thanks for the help so far.
Regards
Craig
