[GRASS-user] installation problems in user space
    Abhinandan Raghavan
    abhinandan.raghavan at gmail.com
    Tue Jul  1 05:00:10 EDT 2008
Thanks for that Glynn. I added the directory with gdal-config to my path and
it configured fine (relief!).
However, when I run make for grass, I get:
Errors in: /home/abhi/lib/grass/visualization/nviz
Finished compilation: Tue Jul  1 10:56:29 CEST 2008
(In case of errors please change into the directory with error and run
'make')
make: *** [default] Error 1
I tried going into "/home/abhi/lib/grass/visualization/nviz" and running
make there and I get the following error:
make[1]: *** [OBJ.x86_64-unknown-linux-gnu/nvizAppInit.o] Error 1
make[1]: Leaving directory `/home/abhi/lib/grass/visualization/nviz/src'
make: *** [nvwish] Error 2
Any clues on what has to be done to progress to other errors ;)
Thanks.
Abhi
On Mon, Jun 30, 2008 at 8:57 PM, Glynn Clements <glynn at gclements.plus.com>
wrote:
> Abhinandan Raghavan wrote:
> > continuing with my woes while trying to install grass, I've managed to
> > install gdal but when I try and compile grass, I get this message:
> > checking for jpeg_start_compress in -ljpeg... yes
> > checking whether to use GDAL... yes
> > yes
> > checking for gdal-config... no
> > configure: error: *** couldn't find gdal-config
> > the options that I've used for the compilation are:
> > a) --with-proj-includes
> > b) --with-proj-libs
> > c)  --with-proj-share
> > d) --with-gdal
> > I'm not sure if something is being missed out. If you are aware of
> anything
> > else that might have gone wrong, then let me know. I use --with-gdal to
> > point to the correct gdal-config file but I still get the message
> "couldn't
> > find gdal-config".
> Contrary to the help text for --with-gdal, the argument is ignored.
> The configure script locates the first executable (binary or script)
> named gdal-config in $PATH.
> If gdal-config exists in $PATH, and is executable, check the
> config.log file for relevant error messages.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080701/a1b1a0a0/attachment-0001.html
