[GRASS-user] Output question - ps.map
Richard Chirgwin rchirgwin at ozemail.com.au
Tue Jul 1 21:28:36 EDT 2008
Thanks, Hamish... to wrap this up, and in case there are any other
newbies to ps.map, the eventual solution was:
1) Go as high as I could go in terms of region resolution, before ps.map
generated out-of-memory errors.
2) Set the paper size to 200" x 200"
RC
Hamish wrote:
> Richard
>> Would it be best to rasterise vector files at high region
>> resolution before trying to get high-quality output? Or
>> should ps.map deliver good results from a vector with high region
>> resolution?
> Vectors work independently of raster resolution, and PostScript is a vector language. Therefore it is strongly advised to keep your vectors as vectors!
> They have "infinite resolution", in the mathematical sense.
> Hamish
