[GRASS-user] error using v.in.gns
maning sambale emmanuel.sambale at gmail.com
Wed Jul 2 03:54:52 EDT 2008
Updating on the svn, I get this configure error
checking for gdal-config... /usr/bin/gdal-config
configure: error: *** Unable to locate GDAL library
Running ldconfig seems that my gdal libarary's are in the right place:
maning at thermaltake:~/source/develbranch_6$ sudo /sbin/ldconfig -p | grep gdal
libgdal1.5.0.so.1 (libc6) => /usr/lib/libgdal1.5.0.so.1
libgdal1.5.0.so (libc6) => /usr/lib/libgdal1.5.0.so
libgdal1.4.0.so.1 (libc6) => /usr/lib/libgdal1.4.0.so.1
cheers,
maning
On 7/2/08, Markus Neteler <neteler at osgeo.org> wrote:
> On Fri, Jun 27, 2008 at 4:26 AM, maning sambale
> <emmanuel.sambale at gmail.com> wrote:
>> I get thios message with v.in.gns:
>> Converted 74072 place names.
>> Scanning input for column types...
>> Unparsable latitude value: LAT
>> Unable to open vector map <gns_data at PERMANENT> on topology level 2
>> AFAIK is used the original data from downloaded from GNS Repo, sample
>> data:
> Yesterday/today, in GRASS SVN (both 6.4.svn and 7.svn) some v.in.ascii
> buffer overflow was fixed (for v.in.geonames which reads in potentially
> better
> quality data than v.in.gns).
> If you can, please update from SVN and try again. Hopefully fixed now.
> Markus
| __.-._  |"Ohhh. Great warrior. Wars not make one great." -Yoda     |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
|  /'.-c  |Linux registered user #402901, http://counter.li.org/     |
|  |  /T  |http://esambale.wikispaces.com|
| _)_/LI
