[GRASS-user] Gdal-config with 6.4svn
maning sambale emmanuel.sambale at gmail.com
Wed Jul 2 06:20:18 EDT 2008
I'm also experiencing the same problem from todays's svn checkout
I'm using ubuntu hardy. I have the same configuration with dokotoreas
cheers,
maning
On 7/2/08, doktoreas <thedoktor78 at gmail.com> wrote:
> Hello everybody.
> Building today svn checkout, I have this error with gdal-config:
> checking whether to use GDAL... yes
> checking for gdal-config... /usr/bin/gdal-config
> configure: error: *** Unable to locate GDAL library.
> 3 days ago, it built with no problem.
> The system is an Ubuntu Hardy with Jachym's repository
> Gdal installed:
> libgdal1-1.4.0
> libgdal1-1.4.0-grass
> libgdal1-1.5.0
> libgdal1-dev
> wich gdal-config:
> gdal related files in /usr/lib/
> libgdal1.4.0.so.1       libgdal1.4.0.so.1.11.4  libgdal1.5.0.a
> libgdal1.5.0.la         libgdal1.5.0.so         libgdal1.5.0.so.1
> libgdal1.5.0.so.1.12.1
> gdal-config --version:
> 1.5.1
> Thanks for your help
> Luca
> http://www.nabble.com/Gdal-config-with-6.4svn-tp18234142p18234142.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
| __.-._  |"Ohhh. Great warrior. Wars not make one great." -Yoda     |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
|  /'.-c  |Linux registered user #402901, http://counter.li.org/     |
|  |  /T  |http://esambale.wikispaces.com|
| _)_/LI
