[POSIBLESPAM]: Re: [POSIBLESPAM]: [GRASS-user] v.in.shape
Jose A. Ruiz-Arias jararias at ujaen.es
Fri Jul 4 13:55:04 EDT 2008
Typing v.in.ogr --help you can read:
        dsn   OGR datasource name
               Examples:
                 ESRI Shapefile: directory containing shapefiles
                 MapInfo File: directory containing mapinfo files
     output   Name for output vector map
      layer   OGR layer name. If not given, all available layers are
        imported
               Examples:
                 ESRI Shapefile: shapefile name
                 MapInfo File: mapinfo file name
dsn is the directory whereas layer your .shp file
Manuel Gerardo Chávez Angeles escribió:
> Marco and Jose,
> Thank you for the feedback.
> This what happen with v.in.ogr
> GRASS 6.3.0 (zonasrurales):~ >  v.in.ogr
> dsn=/manolo/OCDE/GIS/base/Provincias.shp output=provesp
> ERROR: Unable to open data source </manolo/OCDE/GIS/base/Provincias.shp>
> regards
> Manolo
> El 04/07/2008, a las 11:33 AM, Jose A. Ruiz-Arias escribió:
>> v.in.ogr rather than v.in.shape
>>> Any feedback?
>>> GRASS 6.3.0 (zonasrurales):~ > v.in.shape Provincias.shp out=Provesp
>>> bash: v.in.shape: command not found
>>> Manolo
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
