[GRASS-user] Determining maximum value of attributes where areas are overlapping in imported vector layer
Rainer M Krug r.m.krug at gmail.com
Tue Jul 8 09:02:05 EDT 2008
On Tue, Jul 8, 2008 at 10:25 AM, Rainer M Krug <r.m.krug at gmail.com> wrote:
> On Mon, Jul 7, 2008 at 9:37 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Mon, Jul 7, 2008 at 6:28 PM, Rainer M Krug <r.m.krug at gmail.com> wrote:
>>> On Mon, Jul 7, 2008 at 6:19 PM, Markus Neteler <neteler at osgeo.org> wrote:
>>>> On Mon, Jul 7, 2008 at 6:11 PM, Rainer M Krug <r.m.krug at gmail.com> wrote:
>>>>> Hi
>>>>> I am back with a problem of imported shape files:
>>>>> I have imported a shape file and it contains several areas where
>>>>> polygons are overlapping. After I managed to obtain the number of
>>>>> overlapping polygons and exported it to a raster layer
>>>>> (http://grass.osgeo.org/wiki/Vector_Overlapping_Areas), I would now
>>>>> need the maximum value of an attribute column for this areas.
>>>>> Any ideas how I can achieve this?
>>>> You can use 'db.select':
>>>> echo "SELECT max(N1) FROM lidar2" | db.select
>>>> max(N1)
>>>> 512834.76000000000931
>>> Sorry for not being spoecific enough - I want the maximum values as
>>> ributes in an attribute table.
>>> As far as I can see, this just gives me the maximum value of the whole
>>> table - but I need it spatially, i.e. for each area which is
>>> overlapping, the maximum value.
>> Then v.to.db might be helpful.
>> http://grass.osgeo.org/grass64/manuals/html64_user/v.to.db.html
>> -> see qcolumn parameter.
> Thanks - tha is working now.
I was to fast - it is not working.
The reason is the following: if a small polygon A with YEAR=2006 is
completely overlapping with a larger polygon B with YEAR=2000,
max(YEAR) returns 2006 for the whole of polygon B - which is not what
I want. I would like to have 2006 for polygon A and 200 for polygon B,
except of the are where it overlaps with polygon A.
Any ideas on how to achieve this?
Thanks
Rainer
> Rainer
>> Markus
> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
> Biology, UCT), Dipl. Phys. (Germany)
> Plant Conservation Unit
> Department of Botany
> University of Cape Town
> Rondebosch 7701
> South Africa
Rondebosch 7701
South Africa
