[GRASS-user] mapcalc and cell coordinates
Mon Jul 14 09:14:53 EDT 2008
Moritz Lennert wrote:
> Well, this works:
> r.mapcalc brol3=if(y()<=9521600 && x()<=427000,1,null())
> but this doesn't:
> r.mapcalc brol3=if(y()==9521600 && x()==427000,1,null())
> which raises the issue of precision of the coordinates...
What are the region settings? Bear in mind that x() and y() return the
coordinates of the cell's centre, not a corner.
Also note that the calculation involves multiplying by the resolution.
If the resolution cannot be exactly represented as both a binary
fraction and a decimal fraction, you will get rounding error.
[OTOH, if the resolution is an integer, you should be safe.]
More generally, floating point values usually need to be compared to
within some tolerance; see my answer to the original post.
Using == for floating-point values is extremely fragile. In some
situations, even numbers which should be exactly equal won't actually
compare equal (e.g. because the x86 has 80-bit floating-point
registers, but the value will be truncated to 64 bits if stored in a
"double").
Essentially, expect rounding error to occur unless you *know* that all
values involved, including all intermediate results, can be
represented exactly. Compiler optimisations can have an effect, e.g.
-ffast-math (this option isn't enabled by any -O switch).
[BTW, never use Borland's compiler for code which does FP arithmetic.
It "optimises" x/y to x*(1/y), which often introduces rounding error,
and this cannot be disabled.]
