[GRASS-user] building grass6.3.x testing version
Salvator*eL*arosa s_larosa at libero.it
Mon Jul 14 09:40:43 EDT 2008
Hello guys,
I'm trying to compile 6.3 grass but gives me error while
i try to make.
Here my ./configure:
./configure --with-python --with-freetype
--with-freetype-includes=/usr/include/freetype2/
--with-tcltk-includes=/usr/include/tcl8.4 --without-odbc --with-postgres
--with-postgres-includes=/usr/local/pgsql/include
--with-postgres-libs=/usr/lib/  --with-sqlite
--with-wxwidgets=/usr/bin/wx-config --with-readline --with-proj
GRASS is now configured for:  i686-pc-linux-gnu
 Source directory:            /home/sam/pacchetti_mapserver/grass-6.3.0
 Build directory:             /home/sam/pacchetti_mapserver/grass-6.3.0
 Installation directory:      ${prefix}/grass-6.3.0
 Startup script in directory: ${exec_prefix}/bin
 C compiler:                  gcc -g -O2
 C++ compiler:
 Building shared libraries:   yes
 64bit support:               no
 OpenGL platform:             X11
  NVIZ:                       yes
  BLAS support:               no
  C++ support:                no
  DWG support:                no
  FFMPEG support:             no
  FFTW support:               yes
  FreeType support:           yes
  GDAL support:               yes
  GLw support:                no
  JPEG support:               yes
  LAPACK support:             no
  Large File Support (LFS):   no
  Motif support:              no
  MySQL support:              no
  NLS support:                no
  ODBC support:               no
  OGR support:                yes
  OpenGL support:             yes
  PNG support:                yes
  PostgreSQL support:         yes
  Python support:             yes
  Readline support:           yes
  SQLite support:             yes
  Tcl/Tk support:             yes
  wxWidgets support:          yes
  TIFF support:               yes
  X11 support:                yes
  MacOSX application:         no
I have also this problem in ./configure:
checking External PROJ.4 version... 460
checking for location of External PROJ.4 library...
checking for pj_get_def in -lproj... yes
checking for location of External PROJ.4 data files...
configure: warning: *** External PROJ.4 directory not specified; default
will be used
checking for /usr/local/share/proj/epsg... no
configure: warning: *** Unable to locate PROJ data files
My proj data folder is /usr/share/proj/epsg!
This is the error:
Following modules are missing the 'description.html' file in src code:
GRASS GIS compilation log
Started compilation: lun lug 14 16:52:01 CEST 2008
Errors in:
/home/sam/pacchetti_mapserver/grass-6.3.0/gui/wxpython/vdigit
/home/sam/pacchetti_mapserver/grass-6.3.0/visualization/nviz
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: lun lug 14 16:56:56 CEST 2008
make: *** [default] Error 1
Some suggestion?
BYE
Salvatore Larosa
GPG: 0xE504BBE2 (FP: D9B2 CA87 81CD 1B91 E24D 3B42 D0F7 FA01 E504 BBE2)
View this message in context: http://www.nabble.com/building-grass6.3.x-testing-version-tp18444141p18444141.html
Sent from the Grass - Users mailing list archive at Nabble.com.
