[GRASS-user] building grass6.3.x testing version
G. Allegri
giohappy at gmail.com
Mon Jul 14 09:53:28 EDT 2008
The last two errors (wxpython and nviz) should be checked "making" rom
inside the respective folders. Go into gui/wxpython/vdigit and
visualization/nviz and try to compile.
2008/7/14 Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2008/7/14 Salvator*eL*arosa <s_larosa at libero.it>:
>> ./configure --with-python --with-freetype
>> --with-freetype-includes=/usr/include/freetype2/
>> --with-tcltk-includes=/usr/include/tcl8.4 --without-odbc --with-postgres
>> --with-postgres-includes=/usr/local/pgsql/include
>> --with-postgres-libs=/usr/lib/ --with-sqlite
>> --with-wxwidgets=/usr/bin/wx-config --with-readline --with-proj
>> checking External PROJ.4 version... 460
>> checking for location of External PROJ.4 library...
>> checking for pj_get_def in -lproj... yes
>> checking for location of External PROJ.4 data files...
>> configure: warning: *** External PROJ.4 directory not specified; default
>> will be used
>> checking for /usr/local/share/proj/epsg... no
>> configure: warning: *** Unable to locate PROJ data files
>> My proj data folder is /usr/share/proj/epsg!
> Define
> --with-proj-includes=DIRS
> --with-proj-libs=DIRS External PROJ.4 library files are in DIRS
> --with-proj-share=DIR External PROJ.4 data files are in DIR
> Martin
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
