[GRASS-user] i.atcorr and raster compilation errors
    Sebastian P. Luque
    spluque at gmail.com
    Mon Jul 14 10:04:49 EDT 2008
I've been configuring GRASS CVS for a long time as follows:
---<---------------cut here---------------start-------------->---
#! /bin/sh
# GRASS CVS updater and configurer
cd /usr/local/src/grass-cvs
make clean
make distclean
export CVSROOT=3D:pserver:grass-guest at intevation.de:/home/grass/grassreposi=
tory
# cvs login
cvs update -dP
CFLAGS=3D"-g -Wall" ./configure --enable-64bit --with-libs=3D/usr/lib64 \
    --with-tcltk-includes=3D/usr/include/tcl8.4 --with-readline --with-cxx \
    --with-odbc --with-mysql --with-mysql-includes=3D/usr/include/mysql \
    --with-postgres --with-postgres-includes=3D/usr/include/postgresql \
    --with-proj-share=3D/usr/share/proj --with-motif \
    --with-freetype --with-freetype-includes=3D/usr/include/freetype2 \
    2>&1 | tee config_log.txt
---<---------------cut here---------------end---------------->---
However, on compilation I have:
GRASS GIS compilation log
Started compilation: Sat Jul  5 17:41:55 CDT 2008
Errors in:
/usr/local/src/grass-cvs/imagery/i.atcorr
/usr/local/src/grass-cvs/raster/r.terraflow/IOStream/lib/src
In case of errors please change into the directory with error and run 'make=
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Sat Jul  5 17:50:30 CDT 2008
and proceeding as suggested to compile in the offending directories, I
end up with the following for i.atcorr:
-*- mode: compilation; default-directory: "/usr/local/src/grass-cvs/imagery=
/i.atcorr/" -*-
Compilation started at Sat Jul  5 18:02:50
make -k
Makefile:15: warning: overriding commands for target `/usr/local/src/grass-=
cvs/dist.x86_64-unknown-linux-gnu/bin/i.atcorr'
../../include/Make/Module.make:14: warning: ignoring old commands for targe=
t `/usr/local/src/grass-cvs/dist.x86_64-unknown-linux-gnu/bin/i.atcorr'
c++ -I/usr/local/src/grass-cvs/dist.x86_64-unknown-linux-gnu/include  -g -O=
2      -DPACKAGE=3D\""grassmods"\"  -I/usr/local/src/grass-cvs/dist.x86_64-=
unknown-linux-gnu/include -o OBJ.x86_64-unknown-linux-gnu/6s.o -c 6s.cpp
6s.cpp: In function =E2=80=98TransformInput compute()=E2=80=99:
6s.cpp:369: error: =E2=80=98memset=E2=80=99 was not declared in this scope
6s.cpp:599: error: =E2=80=98memcpy=E2=80=99 was not declared in this scope
make: *** [OBJ.x86_64-unknown-linux-gnu/6s.o] Error 1
unknown-linux-gnu/include -o OBJ.x86_64-unknown-linux-gnu/AerosolModel.o -c=
 AerosolModel.cpp
AerosolModel.cpp: In member function =E2=80=98void AerosolModel::parse(floa=
t)=E2=80=99:
AerosolModel.cpp:861: error: =E2=80=98exit=E2=80=99 was not declared in thi=
s scope
AerosolModel.cpp:926: error: =E2=80=98exit=E2=80=99 was not declared in thi=
s scope
make: *** [OBJ.x86_64-unknown-linux-gnu/AerosolModel.o] Error 1
unknown-linux-gnu/include -o OBJ.x86_64-unknown-linux-gnu/computations.o -c=
 computations.cpp
computations.cpp: In function =E2=80=98void os(float, float, float, float, =
float, float (&)[51][49], Gauss&, const Altitude&, const GeomCond&)=E2=80=
=99:
computations.cpp:359: error: =E2=80=98memset=E2=80=99 was not declared in t=
his scope
computations.cpp: In function =E2=80=98void discom(const GeomCond&, const A=
tmosModel&, const AerosolModel&, const AerosolConcentration&, const Altitud=
e&, const IWave&)=E2=80=99:
computations.cpp:1595: error: =E2=80=98memset=E2=80=99 was not declared in =
this scope
make: *** [OBJ.x86_64-unknown-linux-gnu/computations.o] Error 1
make: Target `first' not remade because of errors.
Compilation exited abnormally with code 2 at Sat Jul  5 18:02:51
and for the following directory:
-*- mode: compilation; default-directory: "/usr/local/src/grass-cvs/raster/=
r.terraflow/IOStream/lib/src/" -*-
Compilation started at Sat Jul  5 18:04:40
make -k
2   -D_FILE_OFFSET_BITS=3D64   -DPACKAGE=3D\""grasslibs"\" -I../../include =
-I/usr/local/src/grass-cvs/dist.x86_64-unknown-linux-gnu/include -o OBJ.x86=
_64-unknown-linux-gnu/ami_stream.o -c ami_stream.cc
In file included from ami_stream.cc:29:
../../include/ami_stream.h: In constructor =E2=80=98AMI_STREAM<T>::AMI_STRE=
AM(const char*, AMI_stream_type)=E2=80=99:
../../include/ami_stream.h:233: error: there are no arguments to =E2=80=98s=
trcpy=E2=80=99 that depend on a template parameter, so a declaration of =E2=
=80=98strcpy=E2=80=99 must be available
../../include/ami_stream.h:233: error: (if you use =E2=80=98-fpermissive=E2=
=80=99, G++ will accept your code, but allowing the use of an undeclared na=
me is deprecated)
../../include/ami_stream.h: In member function =E2=80=98AMI_err AMI_STREAM<=
T>::name(char**)=E2=80=99:
../../include/ami_stream.h:341: error: there are no arguments to =E2=80=98s=
trlen=E2=80=99 that depend on a template parameter, so a declaration of =E2=
=80=98strlen=E2=80=99 must be available
../../include/ami_stream.h:342: error: there are no arguments to =E2=80=98s=
make: *** [OBJ.x86_64-unknown-linux-gnu/ami_stream.o] Error 1
Compilation exited abnormally with code 2 at Sat Jul  5 18:04:40
I won't show the log for the last problem directory as it is much
larger, and probably stems from the error above.
GRASS is useable despite these errors, but I've been having these for a
few weeks now, and would appreciate some pointers as to what the problem
is.  Thanks.
Cheers,
Seb
