[GRASS-user] grass 6.3.0 solaris 10 install errors
Brian Clark brclark at usgs.gov
Tue Jul 15 16:19:55 EDT 2008
Glynn Clements wrote:
> Brian Clark wrote:
>> I've included the next round of configure below.... still errors..<br>
>> Ugh; please don't post HTML-only mail to the list.
>>   </pre>
>> </blockquote>
>> sorry - hopefully this will be plain text...<br>
> Alas, no.
try, try again...
>> ok - here's a new configure - (with source directory)<br>
>> <br>
>> GRASS is now configured for:  sparc-sun-solaris2.10<br>
>> <br>
>>  Source directory:            /wattemp/GRASS/grass-6.3.0<br>
>>  Build directory:             /wattemp/GRASS/grass-6.3.0<br>
> Looks okay.
>> and cd to first directory with errors and try make:<br>
>> <br>
>> make OBJ.sparc-sun-solaris2.10<br>
>> make[1]: Entering directory `/wattemp/GRASS/grass-6.3.0/db/drivers/dbf'<br>
>> make[1]: `OBJ.sparc-sun-solaris2.10' is up to date.<br>
>> make[1]: Leaving directory `/wattemp/GRASS/grass-6.3.0/db/drivers/dbf'<br>
>> gcc -I/wattemp/GRASS/grass-6.3.0/dist.sparc-sun-solaris2.10/include
>> -I/usr/local/include/ncurses -g -O2  -I/usr/local/include/ncurses
>> -DPACKAGE=\"\" -I../../../lib/db/dbmi_driver
>> -I/wattemp/GRASS/grass-6.3.0/dist.sparc-sun-solaris2.10/include -o
> Looks okay.
>> OBJ.sparc-sun-solaris2.10/column.o -c column.c<br>
>> column.c:20:24: grass/dbmi.h: No such file or directory<br>
>> column.c:21:23: grass/gis.h: No such file or directory<br>
> Odd; from the top-level source directory, try:
> 	make -C lib headers
> That step is supposed to install the headers into the
> dist.<arch>/include/grass directory, with something like:
>  make[1]: Entering directory `/usr/local/src/grass/svn/lib'
>  if [ ! -d /usr/local/src/grass/svn/dist.i686-pc-linux-gnu/include ]; then mkdir -p /usr/local/src/grass/svn/dist.i686-pc-linux-gnu/include; fi
>  if [ ! -d /usr/local/src/grass/svn/dist.i686-pc-linux-gnu/include/grass ]; then mkdir -p /usr/local/src/grass/svn/dist.i686-pc-linux-gnu/include/grass; fi
>  if [ ! -d /usr/local/src/grass/svn/dist.i686-pc-linux-gnu/include/grass/vect ]; then mkdir -p /usr/local/src/grass/svn/dist.i686-pc-linux-gnu/include/grass/vect; fi
>  if [ ! -d /usr/local/src/grass/svn/dist.i686-pc-linux-gnu/include/Make ]; then mkdir -p /usr/local/src/grass/svn/dist.i686-pc-linux-gnu/include/Make; fi
>  for file in ../include/*.h ; do /usr/bin/install -c  -m 644 $file /usr/local/src/grass/svn/dist.i686-pc-linux-gnu/include/grass/ ; done
>  for file in ../include/vect/*.h ; do /usr/bin/install -c  -m 644 $file /usr/local/src/grass/svn/dist.i686-pc-linux-gnu/include/grass/vect/ ; done
>  for file in ../include/Make/*.make ; do /usr/bin/install -c  -m 644 $file /usr/local/src/grass/svn/dist.i686-pc-linux-gnu/include/Make/ ; done
Ok, got that to work at least once.....and moved on to the next set of
errors...
and after make, then cd to first directory in error list -> make:
gcc -L/wattemp/GRASS/grass-6.3.0/dist.sparc-sun-solaris2.10/lib
-Wl,-R,/wattemp/GRASS/grass-6.3.0/dist.sparc-sun-solaris2.10/lib   -o
/wattemp/GRASS/grass-6.3.0/dist.sparc-sun-solaris2.10/driver/db/dbf
OBJ.sparc-sun-solaris2.10/column.o OBJ.sparc-sun-solaris2.10/cursor.o
OBJ.sparc-sun-solaris2.10/db.o OBJ.sparc-sun-solaris2.10/dbfexe.o
OBJ.sparc-sun-solaris2.10/describe.o OBJ.sparc-sun-solaris2.10/driver.o
OBJ.sparc-sun-solaris2.10/error.o OBJ.sparc-sun-solaris2.10/execute.o
OBJ.sparc-sun-solaris2.10/fetch.o OBJ.sparc-sun-solaris2.10/listtab.o
OBJ.sparc-sun-solaris2.10/main.o OBJ.sparc-sun-solaris2.10/select.o
OBJ.sparc-sun-solaris2.10/str.o OBJ.sparc-sun-solaris2.10/table.o
OBJ.sparc-sun-solaris2.10/create_table.o  -lgrass_dbmidriver
-lgrass_dbmibase -lgrass_gis -lgrass_datetime -lnsl    -lz  -lsocket
-lgrass_dbstubs -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lnsl
-lz  -lsocket    -lgrass_gis -lgrass_datetime -lnsl    -lz  -lsocket
-lgrass_gis -lgrass_datetime -lnsl    -lz  -lsocket    -lgrass_dbmibase
-lgrass_gis -lgrass_datetime -lnsl    -lz  -lsocket     -lgrass_sqlp
-lgrass_shape -lgrass_dbstubs -lgrass_dbmibase -lgrass_gis
-lgrass_datetime -lnsl    -lz  -lsocket    -lgrass_gis -lgrass_datetime
-lnsl    -lz  -lsocket    -lgrass_gis -lgrass_datetime -lnsl    -lz
-lsocket   -lgrass_datetime -lm  -lnsl    -lz
/wattemp/GRASS/grass-6.3.0/dist.sparc-sun-solaris2.10/lib/libgrass_gis.so:
undefined reference to `gethostname at SUNWprivate_1.1'
collect2: ld returned 1 exit status
make: ***
[/wattemp/GRASS/grass-6.3.0/dist.sparc-sun-solaris2.10/driver/db/dbf]
Error 1
Problems with libgrass_gis.so??
thanks,
brc
