[GRASS-user] vdigit in grass64
Salvator*eL*arosa s_larosa at libero.it
Thu Jul 17 03:44:32 EDT 2008
Hello list,
In these days I have built different applications  gfoss
now I find myself with Qgis and Grass64 installed without problems.
The only problem is vdigit of grass that does not work!
Despite the compilation to succeed when I try to edit
vector gives me an error:
Unable to initialize display driver, see README file for
more information.
Details: 'NoneType' object has no attribute 'OpenMap' (No
module named grass6_wxvdigit)
If I try to do "make" in /gui/wxpython/vdigit/ gives me the following error:
gcc: OBJ.i686-pc-linux-gnu/cats.o: No such file or directory
gcc: OBJ.i686-pc-linux-gnu/digit.o: No such file or directory
gcc: OBJ.i686-pc-linux-gnu/driver.o: No such file or directory
gcc: OBJ.i686-pc-linux-gnu/line.o: No such file or directory
gcc: OBJ.i686-pc-linux-gnu/select.o: No such file or directory
gcc: OBJ.i686-pc-linux-gnu/undo.o: No such file or directory
gcc: OBJ.i686-pc-linux-gnu/vertex.o: No such file or directory
gcc: OBJ.i686-pc-linux-gnu/grass6_wxvdigit_wrap.o: No such file or directory
make: *** [OBJ.i686-pc-linux-gnu/_grass6_wxvdigit.so] Error 1
Can someone help me solve the problem?
bye
Salvatore Larosa
GPG: 0xE504BBE2 (FP: D9B2 CA87 81CD 1B91 E24D 3B42 D0F7 FA01 E504 BBE2)
View this message in context: http://www.nabble.com/vdigit-in-grass64-tp18503286p18503286.html
Sent from the Grass - Users mailing list archive at Nabble.com.
