[GRASS-user] Problem displaying a vector map
ramaraju ramarajua at gmail.com
Thu Jul 17 11:38:40 EDT 2008
Hi list
I have prepared a topographic contour map from SRTM image. It was working
all right for quite some time. Recently, I tried to display the map and it
is giving the following message.
PNG: GRASS_TRUECOLOR status: TRUE
PNG: collecting to file:
/home/rr/grassdata/trust_utm/trust/.tmp/rr-lah/10338.0.ppm,
     GRASS_WIDTH=642, GRASS_HEIGHT=455
coor files of vector 'topo_contour at trust' is larger than it should be (14
bytes excess).
The bounding box of the map is outside the current region, nothing drawn.
When I tried making ps file with ps.map it gives a similar message. Can you
say something about the possible problem and how to correct it? I am not
finding any problem while displaying other vector or raster maps. I am using
grass 6.3 on ubuntu 8.04 and also on windows. The problem is same in both
the operating systems. I prepared another contour map, but that too is
giving a similar message
Thanking you in advance
ramaraju
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080717/dc984532/attachment.html
