[GRASS-user] Buffering large grid maps
Milton Cezar Ribeiro
miltinho.astronauta at gmail.com
Mon Jul 21 21:01:42 EDT 2008
Dear R-gurus,
I just started to use GRASS, and I am working with a (almost to me) very
large dataset into GRASS 6.3.0 NATIVE WINDOWS
I imported an Erdas image file using Gdal. Apparently I looks fine, because
GRASS understood and create a Mapset with all informations contained on my
IMG file (like projection, number of cells, bounding box, etc.).
The raster map is 60,000x48,000 pixels.
I tryed display my raster map (it is a binary map with values 0 and 1), but
I can see the binary map.
How can I display my raster map on Map Display 1? I notice that "d.raster
teste" send the output to .tmp directory (or something like).
But my biggest problem is that I need to generate a Distance Map from those
pixels which values is 1.
I tryed "r.buffer input=test output=teste_buffer distances=50,100" (it is in
meters)
but GRASS return a erros message telling that can´t allocate memory
Below is the r.info for the raster that I am trying to "see" and to
"buffer".
My computer is running windows XP, and I have 4Gb of ram memory.
Help are welcome.
Miltinho Astronauta
Brazil
| Layer: teste Date: Mon Jul 21 18:29:17
2008 |
| Mapset: PERMANENT Login of Creator:
user |
newLocation |
| DataBase:
C:/GRASS/database |
| Title: ( teste
| Timestamp:
none |
| Type of Map: raster Number of Categories:
1 |
| Data Type:
CELL |
| Rows:
60184 |
| Columns:
48147 |
| Total Cells:
2897679048 |
| Projection: UTM (zone
-24) |
| N: 9183173.84865143 S: 6173973.84865143 Res:
50 |
| E: 962345.7741373 W: -1445004.2258627 Res:
50 |
| Range of data: min = 0 max =
1 |
| Data
Description: |
| generated by
r.in.gdal |
Comments: |
| r.in.gdal
input="D:/analisebcjulho2008/mergegeral02_julho2008_mata_d\ |
| ila0000m.img"
output="teste" |
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080721/76c84a32/attachment.html
