[GRASS-user] setting monitor device
Tue Jul 22 16:19:22 EDT 2008
Milton Cezar Ribeiro wrote:
> I just intalled the WinGrass 6.3.0 NATIVE for windows and imported a binary
> map on a mapset environment.
> When I try "d.rast myraster" I get:
> PNG: GRASS_TRUECOLOR status: TRUE
> PNG: collecting to file:
> C:/GRASS/database/newLocation/PERMANENT/.tmp/3832.0.ppm,
>      GRASS_WIDTH=387, GRASS_HEIGHT=484
> But no information are showed on "Map Display 1" windows.
> Need I redirect the raster output to "Map Display 1" or it is the default ?
You cannot control the GUI from the command prompt.
The GUI isn't the same thing as a "monitor". The native Windows
version doesn't have monitors.
If you run d.* commands manually on Windows, they just generate an
image file.
