[GRASS-user] Once more: raster projection transformation: LAEA
-> UTM
Glynn Clements
glynn at gclements.plus.com
Tue Jul 22 16:30:54 EDT 2008
Jana K. wrote:
> > My raster data are categorical (landuse), and during the projection
> > transformation I want to go from high resolution (100m) to rather crude
> > resolution (2500m). How GRASS handles such operation? I would expect that It
> > assigns the highest frequency value to the new cell (I mean if one new cell
> > contains 625 old pixels, it will be assigned the value which occurs most
> > frequently). Am I right?
No.
Paul Kelly wrote:
> So I think this clearly suggests that with categorical data your only
> option is nearest neighbor, which doesn't do what you want. Perhaps you
> could resample with r.resamp.stats in the original location before
> reprojecting.
To get the desired result, re-project at high resolution then
downsample with r.resamp.stats *afterwards*.
