[GRASS-user] new user setting up a new mapset/project, part 2
mtnbiketrail at zzz.com
Tue Jul 22 17:52:17 EDT 2008
Okay. some details.
I am working in California maps. I had trouble creating a new
project/mapset, but it is working now. I used r.in.gdal to bring in the
Geotiff and Grass sees it as NAD83 Albers Conical. I tried to use the
command gdalinfo and Grass could not file the file. Even though it is
showing in the Map Display.
Whatever.
here is the g.region -p, I have no idea if it is correct. I don't
understand the negative west, east numbers yet.
projection: 99 (Albers Equal Area)
zone: 0
datum: nad83
ellipsoid: grs80
north: 405480.97282175
south: 391273.11966856
west: -271733.88910031
east: -260832.03532599
nsres: 1.52772615
ewres: 1.52772615
rows: 9300
cols: 7136
cells: 66364800
My next question is: I need this base Geotiff in UTM WGS84. From what
the other email said, I have to create a new location. Does the area
covered have to be the same? I am still having a hard time with the
project region syntax.
I also have GPS waypoints(in UTM, WGS84) I want to bring into the
mapset. From what I read points should be treated as vectors? Is there a
way to mass import points into the database?
I ordered the Neteler book, I hope it has real examples.
Thanks,
Tom
Tom Russo wrote:
> On Sun, Jul 20, 2008 at 08:28:54PM -0700, we recorded a bogon-computron collision of the <mtnbiketrail at zzz.com> flavor, containing:
>> I'm confused.
>> I want to set up a new project and use UTM wgs 84.
>> But, some of my data is drg(base USGS topo map), which are lat/long,
> Most USGS DRG topo maps are georeferenced in UTM (only those that have been
> monkeyed with by other agencies are not). Some state and local GIS departments
> reprocess them with software that removes the TIFF tags that GDAL would use
> to figure out what to do with them, even when they don't change the projection.
> Any USGS topo for California will have been reprojected to an equal-area
> projection, and any USGS topo covering territory under the authority of the
> Tennesee Valley Authority will be in UTM but with no geotiff tags necessary
> for GDAL to recognize them. But real USGS topos for any other part of the
> US should be in UTM and have GeoTIFF tags identifying the coordinate system.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080722/015d5e73/attachment.html
