[GRASS-user] running several command in batch.
Daniel Victoria daniel.victoria at gmail.com
Wed Jul 23 08:52:28 EDT 2008
Hi Milton,
You can put all commands in a shell script (sort of like .bat files in
MS-DOS) and call the script from the "Output Gis.m". Or you could run
grass from a terminal (xterm) and call the shell script.
I believe the only commands that won't work in these scripts are the
d.* commands. All of the rest you can use with no problem.
qq coisa é só gritar (yell if you need help)
Daniel
On Wed, Jul 23, 2008 at 1:41 AM, Milton Cezar Ribeiro
<miltinho.astronauta at gmail.com> wrote:
> Dear all,
> How can I run a set of command in batch mode on Windows Native GRASS 6.3.0.
> I am running my sequence of commands on "Output Gis.m" modele of native
> windows,
> doing copy and past from a notepad.
> But when I try copy more than one command, I get error.
> By the way, each of my command generate an output raster that will be used
> on next command.
> Kind regards,
> Miltinho Astronauta
> Brazil
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
