[GRASS-user] import a folder full of shapefiles and reproject
on-the-fly?
Moritz Lennert
mlennert at club.worldonline.be
Wed Jul 23 17:09:38 EDT 2008
On 23/07/08 22:36, Maciej Sieczka wrote:
> Tim Michelsen pisze:
>> Is there any way that I can import all tiles at once and also
>> reprojecting the CLC shapes into LL?
> Use ogr2ogr to reproject Shapefiles outside GRASS (it accepts directory
> of shapefiles as input as well as single shapefiles) and then import
> them all with v.in.ogr. You can automate v.in.ogr in Shell using "for in
> do" syntax (plenty of examples in the archive or Google it).
I don't think you actually need a for-loop. From the v.in.ogr man page:
layer=string[,string,...]
OGR layer name. If not given, all available layers are imported
So, normally, if you don't give a layer all the shapefiles in the
directory (dsn=) will be imported.
You will, however, need a loop for the v.proj step...
Moritz
