[GRASS-user] gis.m will not load
brendon wolff-piggott mytekmail at gmail.com
Thu Jul 24 12:50:35 EDT 2008
Hi all
I am running Grass 6.2.3 under Cygwin on a laptop with 512MB RAM and Windows
XP.  I can run Grass from the command line, but when I try to load the gis
manager with "gis.m &", it appears for a split second and than exits (see
screendump below).
Does anyone have an idea why it is doing this?
Thanks
Brendon Wolff-Piggott
/ integrated geodata solutions /
/ pretoria, republic of south africa /
GRASS 6.2.3 (test):~ > gis.m &
[1] 2440
GRASS 6.2.3 (test):~ > child process exited abnormally
Error in startup script: can't read "monitor_zooms(1,1,n)": no such variable
    while executing
"lappend region $monitor_zooms($mon,1,$attr)"
    (procedure "MapCanvas::currentzoom" line 13)
    invoked from within
"MapCanvas::currentzoom $mon"
    (procedure "MapCanvas::coordconv" line 23)
    invoked from within
"MapCanvas::coordconv $mon"
    (procedure "MapCanvas::create" line 68)
    invoked from within
"MapCanvas::create"
    (procedure "Gm::startmon" line 11)
    invoked from within
"Gm::startmon"
    (procedure "Gm::create" line 69)
    invoked from within
"Gm::create"
    (procedure "main" line 30)
    invoked from within
"main $argc $argv"
    (file "/usr/local/grass-6.2.3/etc/gm/gm.tcl" line 521)
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080724/276777de/attachment.html
