[GRASS-user] tips on GRASS Mac users
Michael Barton
michael.barton at asu.edu
Fri Jul 25 12:34:54 EDT 2008
On Jul 25, 2008, Kyngesburye at 9:00 AM, <grass-user-request at lists.osgeo.org
> wrote:
> Date: Fri, 25 Jul 2008 09:34:27 -0500
> From: William <woklist at kyngchaos.com>
> Subject: Re: [GRASS-user] tips on GRASS Mac users
> To: maning sambale <emmanuel.sambale at gmail.com>
> Cc: grass-user at lists.osgeo.org
> Message-ID: <3E1C329C-B8C1-42C4-A379-B9F38867CE77 at kyngchaos.com>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed; delsp=yes
> On Jul 25, 2008, at 12:55 AM, maning sambale wrote:
>> How to configure middle-click for the zooming function in GRASS with
>> imacs mighty mouse?
> GRASS (X11) takes mouse buttons as they are assigned in System
> Preferences->Keyboard & Mouse. ie, if you set your mouse right-
> handed, the left and right will be switched in GRASS also. I believe
> the middle button on the mighty mouse defaults to some OS feature (I
> don't have an iMac handy, but can check later), so you need to change
> it to a normal middle button.
> I think there's also a key you can use in GRASS to emulate a middle-
> click but I can't find it in the docs.
This is also determined by the system. Ctrl-click = right-click,
option-click = middle-click
Michael
> Tip: disable the side squeeze buttons, I found that they are too
> sensitive (unless recent models have improved), and when lifting the
> mouse to recenter it on the mousepad it's easy to accidentally trigger
> Exposé.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> The equator is so long, it could encircle the earth completely once.
