[GRASS-user] using v.digit with translucent background
    Glynn Clements
    glynn at gclements.plus.com
    Thu Jul 31 14:37:24 EDT 2008
Juan Manuel Barreneche wrote:
> i want to use v.digit with two overlayed raster maps, both of which cover
> the entire area i'm working, so i need the raster "on top" be translucent to
> some extent (say, %50 opacity)
> is there a way to do that with the bgcmd argument of v.digit?
No.
However, you can use r.blend to produce a blend between two maps, then
use the blended map as the background.
