[GRASS-user] Re: grass-user Digest, Vol 25, Issue 67
Otto Dassau
otto.dassau at gmx.de
Mon Jun 2 05:42:56 EDT 2008
good idea - we could update ./rpm/suse from time to time. I don't have svn
access for grass but I can send you the spec files, if you like. Who would be
the contact person, I can send the files to? Would that be ok?
Attached you find the current spec file and the patch which comments the
wxpythion v.digit module for the grass 6.3. The same files are available in
the /src folder via the Application:/Geo/ repository. It works for OpenSuSE
10.2, 10.3 and openSUSE_Factory.
regards,
Otto
On Fri, 30 May 2008 23:01:26 -0700 (PDT)
Hamish <hamish_b at yahoo.com> wrote:
> Hamish:
> > > I do not know if the SuSE packages are build using the
> > spec from the GRASS source code, but you could check the
> > rpm/ source code dir and submit any fixes you have.
> > > http://trac.osgeo.org/grass/browser/grass/trunk/rpm
> Richard Chirgwin wrote:
> > I think you may be flattering my expertise if you think
> > I'm competent for source code fixes! :-)
> I don't think it's quite as hard as you might think- just to look at the text
file and see what's there. Anyway I encourage all to explore it even if you are
not comfortable with making too many changes.
> The package dependency part of the spec file seems fairly clear. e.g.:
http://trac.osgeo.org/grass/browser/grass/trunk/rpm/suse/grass-6.1.cvs-1suse.spec
> Requires: gdal >= 1.3
> Requires: tcl >= 8.3
> Requires: tk >= 8.3
> Requires: proj >= 4.4.9
> adding another is just opening it up in a text editor and typing the line.
> But it is probably better to sync that with Otto's 6.3.0 version before doing
any more, as the GRASS svn copy is way out of date.
> > I should however say, wrt YaST on OpenSuSE, that it's
> > very ignorant of Grass and only returns a very ancient version
> > (5.0.3-120).
> Hmm, maybe someone could work on getting Otto's OpenSuSE packages into that.
> http://download.opensuse.org/repositories/Application:/Geo/
> (no idea)
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080602/ab686aba/grass-6.3.0_wx-vdigit-0001.bin
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080602/ab686aba/grass-0001.obj
