[GRASS-user] Landsat color correction fails with "Segmentation
fault" in GRASS 6.3
Marius Jigmond
mariusjigmond at hotmail.com
Mon Jun 2 19:36:21 EDT 2008
Hamish,
Here are the outputs:
1. GRASS 6.3.0 (Romania):~ > r.univar -ge RGB321.3 at marius perc=98
n=68587026
null_cells=3781910
min=58
max=255
range=197
mean=181.261
mean_of_abs=181.261
stddev=36.808
variance=1354.83
coeff_var=20.3067
sum=12432135110
Segmentation fault
2. GRASS 6.3.0 (Romania):~ > g.region -p
projection: 99 (sterea)
zone: 0
datum: ** unknown (default: WGS84) **
ellipsoid: a=6378245 es=0.006693421622965943
north: 773383.051
south: 194663.051
west: 103791.364
east: 904111.364
nsres: 80
ewres: 80
rows: 7234
cols: 10004
cells: 72368936
3. After setting DEBUG=1
GRASS 6.3.0 (Romania):~ > i.landsat.rgb red=RGB321.3 at marius
green=RGB321.2 at marius blue=RGB321.1 at marius
Processing <RGB321.3 at marius> ...
Segmentation fault
D1/1: <RGB321.3 at marius>: min=108 max=
ERROR: bad rule (syntax error): white
Processing <RGB321.2 at marius> ...
Segmentation fault
D1/1: <RGB321.2 at marius>: min=129 max=
Processing <RGB321.1 at marius> ...
Segmentation fault
D1/1: <RGB321.1 at marius>: min=137 max=
I am not sure why it says "datum: unknown," it's the "Dealul Piscului
1970" datum (using the EPSG 31700). I don't think it's related to the
error though.
Thanks for looking into it.
Marius
Hamish wrote:
Marius Jigmond wrote:
Have you run into this kind of errors:
Nope.
GRASS 6.3.0 (Romania):~> i.landsat.rgb
red=RGB321.3 at marius green=RGB321.2 at marius blue=RGB321.1 at marius
Processing ...
Segmentation fault
Processing ...
Segmentation fault
Processing ...
Segmentation fault
It's a three band Landsat mosaic. I am running Ubuntu
8.04 with GRASS 6.3 from Jachym Cepicky's repo
(http://les-ejk.cz/ubuntu/). I am not
really sure where to start poking.
It would seem that r.univar is failing in this part of the i.landsat.rgb script:
for i in $RED $GREEN $BLUE ; do
g.message "Processing <$i> ..."
MIN=`r.univar -ge $i perc=2 | grep "^percentile_" | cut -d'=' -f2`
MAX=`r.univar -ge $i perc=$BRIGHTNESS | grep "^percentile_" | cut -d'=' -f2`
g.message -d message="<$i>: min=$MIN max=$MAX"
r.colors $i col=rules << EOF
0% black
$MIN black
$MAX white
100% white
EOF
done
so $MAX would be unset, and r.colors gets a color without a value, which is a bad rule.
can you try "r.univar -ge RGB321.3 at marius perc=98" on the command line and see what happens?
also, what does "g.region -p" look like?
and finally can you rerun i.landsat.rgb with debug messages turned on?
g.gisenv set="DEBUG=1" # to turn them back off set to 0
then the g.message info will be displayed.
but why does r.colors not complain about "$MIN black" too?
Hamish
_________________________________________________________________
Make every e-mail and IM count. Join the i’m Initiative from Microsoft.
http://im.live.com/Messenger/IM/Join/Default.aspx?source=EML_WL_ MakeCount
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080602/783dc8e6/attachment.html
