[GRASS-user] Segmentation fault with i.atcorr
maning sambale
emmanuel.sambale at gmail.com
Tue Jun 3 05:27:32 EDT 2008
I'm getting segmentation fault using i.atcorr on a LANDSAT TM data. I
subsetted the image to test in a small region.
projection: 1 (UTM)
zone: 51
datum: wgs84
ellipsoid: wgs84
north: 646722
south: 641763
west: 744135
east: 749436
nsres: 28.5
ewres: 28.5
rows: 174
cols: 186
cells: 32364
i.atcorr -b iimg=p112r056_20000213_b1.rad at PERMANENT
iscl=-6.978740,191.600 icnd=/home/maning/icnd_band1p112r056
oimg=test_p112r056_b1.rad.atcorr oscl=0,255 --overwrite
sample icnd
8 (TM)
02 13 2.30 125.1297377 5.7841158 (Geometrical conditions)
1 (Tropical)
1 Continental
15 visibility
-.600
-1000
61 (chosen band)
6s version 4.2b ******************************
* geometrical conditions identity
* etm+ observation
* month: 2 day: 13 *
* solar zenith angle: 30.48 deg solar azimuthal angle: 128.88 deg *
* view zenith angle: 0.00 deg view azimuthal angle: 0.00 deg *
* scattering angle: 149.52 deg azimuthal angle difference: 128.88 deg *
* atmospheric model description
* atmospheric model identity :
* tropical (uh2o=4.12g/cm2,uo3=.247cm-atm)
* aerosols type identity :
* Continental aerosols model
* optical condition identity :
* visibility : 15.00 km opt. thick. 550nm : 0.3158 *
* spectral condition
* etm+ 1
* value of filter function :
* wl inf= 0.435 mic wl sup= 0.520 mic *
* target type
* homogeneous ground
* constant reflectance over the spectra 0.000 *
* target elevation description
* ground pressure [mb] 946.12 *
* ground altitude [km] 0.600 *
* gaseous content at target level:
* uh2o= 3.104 g/cm2 uo3= 0.246 cm-atm *
* atmospheric correction activated
Percent complete: Segmentation fault (core dumped)
maning
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |http://esambale.wikispaces.com|
| _)_/LI
