[GRASS-user] raster data to ascii
Hamish
hamish_b at yahoo.com
Wed Jun 4 21:05:19 EDT 2008
Glynn:
> r.resample makes a direct copy of its input, resampled using GRASS'
> built-in nearest-neighbour resampling, so r.resample only has limited
> utility.
> [AFAICT, it's primary use is to reduce disk space and/or CPU usage. If
> you will be reading a map repeatedly at a significantly
> reduced resolution, using a resampled copy may be faster than
> having GRASS continually resample the higher resolution version.]
there is a question in the wiki about GRASS 7 development:
to remove r.resample (as redundant) or not?
thoughts?
Hamish
