[GRASS-user] Which gauss-krueger projection ?
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Mon Jun 9 15:47:27 EDT 2008
On Mon, 2008-06-09 at 21:40 +0200, Nikos Alexandris wrote:
> My problem is that I am not sure if one of the options (besides the
> whole-country) deals with the bounding box of my interest:
> Those are (in metres)
> N: 5580000 S: 5490000
> E: 2644000 W: 2534000
> And I am not sure whiche transformation parameters to use to convert
> them to degrees ;-)
For example, is the following transformation correct?
gdaltransform -s_srs epsg:31466 -t_srs epsg:4326
2534000 5490000
6.46925611791806 49.5458035746045 5.23711311891839
2534000 5580000
6.4771846139954 50.3549233866055 3.37402869747075
2644000 5490000
7.9886508632139 49.5296632215733 4.35285628430074
2644000 5580000
8.02222474710927 50.3383168074372 2.4900523843271
That is latitude ranging from 49.5458035746045 to 50.3549233866055
Then I should use option 6 (?)
It just that I am not sure about the exact transformation parameters.
Nikos
