[GRASS-user] Error in v.vol.rst
Manuel Seeger
seeger at uni-trier.de
Tue Jun 10 02:28:20 EDT 2008
Hallo Frühaufsteher!
Here is the output of gregion -p3
projection: 1 (UTM)
zone: 30
datum: wgs84
ellipsoid: wgs84
north: 4681874.175
south: 4681826.55
west: 624764.175
east: 624839.625
top: 343.00000000
bottom: 337.00000000
nsres: 0.075
nsres3: 0.10005252
ewres: 0.075
ewres3: 0.10006631
tbres: 0.01
rows: 635
rows3: 476
cols: 1006
cols3: 754
depths: 600
cells: 638810
3dcells: 215342400
Thanks!
Manuel
Markus Neteler schrieb:
> Hallo Manuel,
> das war g.region -p aber nicht g.region -p3
> Markus
> On Mon, Jun 9, 2008 at 8:35 AM, Manuel Seeger <seeger at uni-trier.de> wrote:
>> Hello Markus, hello Hamish, and List!
>> I imported a transformed shapefile.
>> g.region -p gives:
>> projection: 1 (UTM)
>> zone: 30
>> datum: wgs84
>> ellipsoid: wgs84
>> north: 4681874.175
>> south: 4681826.55
>> west: 624764.175
>> east: 624839.625
>> nsres: 0.075
>> ewres: 0.075
>> rows: 635
>> cols: 1006
>> cells: 638810
>> as it is a gully headcut, I have steep slopes (vertical!) and overhangs and
>> some shadowing...
>> Thanks again!
>> Manuel
>> Hamish schrieb:
>>> Manuel Seeger wrote:
>>>> I trying to generate a 3d DEM of a gully headcut. The point
>>>> data was gained by terrestrial laser scanner.
>>> what is the form of the raw data? x,y,z point cloud?
>>> is there only one x,y for each z, or are there overhangs?
>>> I ask because if there is only one z for each x,y then perhaps a 2.5D
>>> surface is more appropriate and the processing is much simpler:
>>> http://grass.osgeo.org/wiki/Help_with_3D#Raster_2.5D_Surfaces
>>> that may obscure fine details of steep slopes though, lumping them all
>>> into one horizontal cell. Maybe the cell resolution would have to be very
>>> small.
>>> If that isn't good enough an idea, if you don't mind it, is to switch the
>>> z coordinate with x or y when you import and then look at the thing side on.
>>>> As I am doing my first attempts, I do not change any
>>>> parameters from that given by default.
>>>> This is the result:
>>>> v.vol.rst input=BAR1_SCAN_UTM at Georef41 wcolumn=dbl_3 tension=40.
>>>> smooth=0.1 segmax=50 npmin=200 dmin=0.050026 wmult=1.0 zmult=1.0
>>>> elev=Olite_3d --overwrite
>>>> 1511728 records selected from table
>>>> some points outside of region -- will ignore...
>>>> strip exists with insufficient data
>>>> Processing all selected output files will require 1435616
>>>> bytes of disk space for temp files
>>>> There are points outside specified 2D/3D region--ignored
>>>> 57754 points (total points: 1511728)
>>>> Points are more dense than specified
>>>> 'DMIN'--ignored 1131669 points (remain 380059)
>>>> Percent complete:
>>>> Error in COGRR!
>>>> Interp_call failed!
>>>> Can someone give me an idea if this is my fault?
>>> No idea about that.
>>> Hamish
>> _______________________________________________________________________
>> Dr. Manuel Seeger
>> Wiss. Assistent Scientific Assistant
>> Physische Geographie Dpt. of Physical Geography
>> FB VI - Geographie/Geowissenschaften Geography/Geosciences
>> Universität Trier University of Trier
>> D - 54286 Trier
>> Tel.: +49-651-201 4557
>> Fax: +49-651-201 3976
>> Web: http://www-neu.uni-trier.de/index.php?id=9607
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Dr. Manuel Seeger
D - 54286 Trier
