[GRASS-user] using v.line.center
Manuel Sangiao
masanlo1 at gmail.com
Tue Jun 10 08:01:24 EDT 2008
Dzie,kuje bardzo Maciej,
It has worked,
2008/6/6 Maciej Sieczka <tutey at o2.pl>:
> Manuel Sangiao pisze:
>> Hi all,
>> after the reprojection in another mapset I used v.line.center, all
>> ok. But, I obtain a new layer without database. The input layer have
>> database.
> v.line.center does not copy the input vector's table to output vector.
> v.db.connect -p glines1 Vector map <glines1> is connected by: layer
>> <2> table <glines1> in database
>> </scratch/manuel/GISDATA//admprojected/manuel/dbf/> through driver
>> <dbf> with key <cat>
> I have read that the result layer (pts1) contains the category
>> numbers of the input vector line layer.
>> Is there a solution?
> Yes. As the category numbers are the same, you can:
> # given that the name of the v.line.center's input vector is "lines" and
> # the output is "points":
> # copy the input table:
> db.copy from_table=lines to_table=points
> # connect the table "points" to vector map "points":
> v.db.connect points table=points
> Now query (d.what.vect, v.db.select) to check if everything's OK.
> Mind that I assume plenty of defaults in the example above - verify your
> layer number, key column name etc. Refer to to commands's manuals.
> Maciek
> Maciej Sieczka
> www.sieczka.org
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080610/66949b4f/attachment.html
