[GRASS-user] i.rectify with DMS degrees
Hamish
hamish_b at yahoo.com
Thu Jun 12 14:19:39 EDT 2008
Alfredo:
> Can I rectify scanned maps with the tool georectify by DMS
> degrees (Degree:Minute:Second) ?
> Or I can utilise only DD decimal degrees?
I don't know about the others, but i.points for sure and probably i.vpoints accepts DDD:MM:SS.SSSSH. Make sure you include the hemisphere at the end and make minutes (& sec?) as two digits if less than ten (e.g. "05").
I think the v.in.ascii help page has the syntax for that.
Hamish
