[GRASS-user] Enclose the polygons within 50 metres
Gabriele N.
gis.gn at libero.it
Tue Jun 17 12:53:42 EDT 2008
Hi Christian
Indeed this was doing. I made the buffer (but on many polygons gives a bit
of problems)
and now , as suggested by you, I can go to raster with v.to.rast.
Or should I try to dissolve the buffer by working again with the vector.
Thanks
Gabriele
Christian Schwartze-2 wrote:
> Hi,
> don't know if I unterstood you right, but what about buffering your
> polygons (v.buffer with buffer=50m), i.e. the buildings. So you get a
> map of overlapping areas where features not more far away than 50
> meters. Afterwards you can use v.to.rast for rasterizing the buffer
> zones and describing small towns for you case.
> Regards,
> Christian.
> Am Sonntag, den 15.06.2008, 08:43 -0700 schrieb Gabriele N.:
>> Hi all
>> I have 2 vector polygonal; one representing the buildings and another
>> that
>> represents the infrastructure.
>> I think to put them together with v.patch.
>> I have to create another vector polygonal, which is to enclose all the
>> polygons that are close to each other within 50 metres. I need to
>> identify
>> small towns.
>> How can I do?
>> 1) v.patch
>> 2) v.distance?
>> 3)?
>> Thank you very much
>> Gabriele
> This mail was sent through http://webmail.uni-jena.de
> grass-user mailing list
> grass-user a lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://www.nabble.com/Enclose-the-polygons-within-50-metres-tp17851388p17919567.html
Sent from the Grass - Users mailing list archive at Nabble.com.
