[GRASS-user] low radiance values after i.atcor and i.topo.corr
maning sambale
emmanuel.sambale at gmail.com
Wed Jun 18 06:57:14 EDT 2008
On 6/18/08, Glynn Clements <glynn at gclements.plus.com> wrote:
> maning sambale wrote:
>> >> After implementing gain and bias correction and topographic
>> >> correction, I get very low values for landsat data data
>> >> for example range of values of band1:
>> >> GRASS 6.3.1svn (p112r056):~ > r.info lsat7_2000.toar.1 -r
>> >> min=0.030303
>> >> max=0.372067
>> >> Running these range of values to an i.cluster reports very low
>> >> separability:
>> > As far as I see it is related to the fact that i.cluster reads in as
>> > integer (CELL)
>> > through G_get_c_raster_row():
>> > http://download.osgeo.org/grass/grass6_progman/gis_2get__row_8c.html
>> >> I assume this is due to the very low range of values (0.0xxx) of the
>> >> input images. Running r.rescale.eq to "stretch" the range of values
>> >> doesn't also help.
>> > You may try to multiply the values with 100 or 1000 using r.mapcalc.
>> > Please let us know how it works.
>> Thanks! Multiplying by 1000 with r.mapcalc gives better results. Any
>> chance adding floating points (FCELL) to i.cluster?
> I had a brief look at the code[1], and cannot see any obvious reason
> why the values would need to be integers, so I'm assuming that it's
> just a legacy of the days before FP support was added.
> [1] Most of the code is actually in the lib/imagery/c_*.c files. That
> should either be made part of i.cluster (nothing else uses it), or at
> least split into a separate library.
Excellent! I hope it gets fixed. I am glad reporting such problems
(though at times trivial) helps improve the GRASS code.
cheers,
maning
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |http://esambale.wikispaces.com|
| _)_/LI
