[GRASS-user] i.spec.unmix module
Pedro Camilo Alcantara camilo at pcbiol.posgrado.unam.mx
Wed Jun 18 09:30:52 EDT 2008
Hi everyone
I saw that there is a module on spectral unmixing on the add-ons subversion
repository, so, I downloaded and compiled the last grass 6.4 snapshot
(grass-6.4.svn_src_snapshot_2008_06_14), download the addons with svn (svn
checkout https://svn.osgeo.org/grass/grass-addons/ grass-addons). and
compiled the module as described in the README I found on the addons (make
MODULE_TOPDIR=/home/camilo/grass-6.4.svn_src_snapshot_2008_06_14).
I got this messages:
/home/camilo/grass-addons/imagery/i.spec.unmix# make
gcc
-I/home/camilo/grass-6.4.svn_src_snapshot_2008_06_14/dist.i686-pc-linux-gnu/include
-g -O2       -DPACKAGE=\""grassmods"\"
-o OBJ.i686-pc-linux-gnu/main.o -c main.c
main.c: In function 'main':
main.c:172: warning: passing argument 2 of 'G_vector_norm_maxval' makes
integer from pointer without a cast
main.c:178: warning: passing argument 2 of 'G_vector_norm_maxval' makes
main.c:227: warning: assignment makes pointer from integer without a cast
main.c:231: error: expected expression before '[' token
main.c:231: error: too few arguments to function 'G_matrix_get_element'
main.c:231: error: 'mat_struct' has no member named 'G_matrix_get_element'
main.c:235: error: expected expression before '[' token
main.c:235: error: too few arguments to function 'G_matrix_get_element'
main.c:262: warning: assignment makes pointer from integer without a cast
main.c:263: error: 'mat_struct' has no member named 'm'
main.c:263: warning: assignment makes pointer from integer without a cast
main.c:264: error: 'mat_struct' has no member named 'm'
main.c:264: warning: assignment makes pointer from integer without a cast
main.c:265: error: 'mat_struct' has no member named 'n'
main.c:265: warning: assignment makes pointer from integer without a cast
main.c:266: error: 'mat_struct' has no member named 'm'
main.c:266: error: 'mat_struct' has no member named 'n'
main.c:266: warning: assignment makes pointer from integer without a cast
main.c:293: error: 'mat_struct' has no member named 'm'
main.c:293: warning: assignment makes pointer from integer without a cast
main.c:295: error: 'vec_struct' has no member named 've'
main.c:297: error: 'vec_struct' has no member named 've'
main.c:306: error: 'mat_struct' has no member named 'n'
main.c:307: error: 'vec_struct' has no member named 've'
main.c:307: error: 'mat_struct' has no member named 'n'
main.c:324: error: 'mat_struct' has no member named 'n'
main.c:325: error: 'vec_struct' has no member named 've'
main.c:326: error: 'vec_struct' has no member named 've'
main.c:339: warning: assignment makes pointer from integer without a cast
main.c:349: error: 'vec_struct' has no member named 've'
main.c:383:28: warning: missing terminating " character
main.c:383: error: missing terminating " character
main.c:384: error: expected ')' before numeric constant
main.c:384: error: stray '\' in program
main.c:385: error: stray '\' in program
main.c:386: error: stray '\' in program
main.c:387:11: warning: missing terminating " character
main.c:387: error: missing terminating " character
main.c:391: error: expected ';' before '}' token
make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
I am using a debian server with Linux 2.6.22-3-686 #1 SMP Sun Feb 10
20:20:49 UTC 2008 i686 GNU/Linux
Is there any other way to compile this module? or is just that is under
development?
Best
camilo
Pedro Camilo Alcántara Concepción
Department of Forest and Wildlife Ecology
Rm. 120 Russell Labs
1630 Linden Dr.
Madison WI 53706-1598
Phone +1/608/265-9219
http:/silvis.forest.wisc.edu
___________________________________________
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080618/05fecaab/attachment-0001.html
