[GRASS-user] OpenOSX Grass: x11 installed but not found!
Glynn Clements
glynn at gclements.plus.com
Sat Jun 21 05:31:32 EDT 2008
backspaces wrote:
> I just installed the OpenOSX Grass (non-pro) version.
> When I start the application, it complains that there is no X11 installed:
> Missing Apple X11
> This application requires Apple's X11. Please install X11 and try again.
> Would you like to open the Apple X11 page in your web browser?
> But X11 *is* installed! I can start xterm and so on. Is this just yet
> another reason for me to use the "framework" version of the OS X Grass
> release for Mac? I very carefully made sure X11 was installed when I
> installed Leopard. It shows up in the Applications/Utility folder and
> responds just fine when I double click on it. I've also got the Developer
> installation, which has X11 libraries. I mean I'm like totally X11!
> So I guess the questions are:
> - Is OpenOSX Grass broken?
> - Is every thing just fine, other than a spurious error message?
> - Is there a secret trick for telling apps that X11 *is* installed?
> - Would it be better to use one of the other OSX Grass installations?
I suggest that you first try the version from the GRASS website:
http://grass.osgeo.org/grass63/binary/macosx/
If you have problems with the OpenOSX versions, you would be better
off asking OpenOSX. AFAIK, none of the GRASS developers are
particularly familiar with the OpenOSX version.
I suspect that the problem is that the OpenOSX version is out of date.
Apple's X11 support is something of a moving target. IIRC, prior to
Leopard, it was necessary to explicitly start X11, but that isn't
necessary (and doesn't work) in Leopard.
