[GRASS-user] mask in PERMANENT affect on other mapsets during
reprojection
Jarekj
jarekj at amu.edu.pl
Sun Jun 29 10:48:27 EDT 2008
The situation is as follows:
In location GRS mapset PERMANET I have MASK (with projection of 2180
based on GRS elipsoid)
in second mapset let say jarekjaI have map which is to be reprojected to
other location (WGS). In that mapset no MASK is present.
In location WGS mapset PERMANENT I reporject map from location GRS and
I have only fragment allowed by MASK from GRS PERMANENT It is intended
or some bug?
Jarek
